I am creating a fixed blade knife in inventor and I wanted to put a saber grind on it but I cannot figure out how to do it. I have tried using the chamfer tool but the grind does not go far enough up the blade. Does anyone know how i could make this work?
Solved by mcgyvr. Go to Solution.
I didn't open your file but have you tried doing a "sweep"
@dylanr747 wrote:
I have but I'll admit that I am still learning sweep so I may not be using it right.
Well now is a perfect time to play/learn then 🙂
Going back to chamfer there is also the ability to select "distance and angle" and "distance/distance" instead of just one fixed distance.
You might also have to use "split" or similar to define where the chamfer will start/stop.
