Inventor General
Member
timurt
Message 1 of 4 (293 Views)
I get Length in cm but Units are inch
293 Views, 3 Replies
06-01-2011 10:59 PM
Hi guys,
I'm novice in Inventor API.
I have a stuped question:
I see that I get hole diameter in cantimeters:
m_Feature->HoleDiameter->Value
But units are inches:
m_Feature->HoleDiameter->GetUnits();
Units of the document are also inches, and Inventor GUI also displays inches.
So my question - why I get the length in cm? It seems like a bug.
Employee
Message 2 of 4 (276 Views)
Re: I get Length in cm but Units are inch
06-02-2011 06:19 AM in reply to: timurt
Hi -
This is as designed. The API will always use what it calls "database units" to return (and receive) such values. There are "UnitsOfMeasure" objects available to convert between units and expressions.
For length, cm is always used.
Hope this helps,
  Jeff
Distinguished Contributor
Message 3 of 4 (273 Views)
06-02-2011 07:01 AM in reply to: timurt
If this was downloaded then this part was probably made in metric. If someone else at work made the part that did a override and inputted the dim as metric. When creating a feature you can over ride and manually inert any unit of length in the radio button for the dim callout you would like. This allows you to if you are mating two parts one in inches and one in metric to get them to mate without have to convert dim. So you can have a part model with mixed dim's. You're part drawing should come out as all inches if that is what the format is set to. IV is unitless unlike Autocad.
msk
Member
timurt
Message 4 of 4 (226 Views)
06-20-2011 10:11 PM in reply to: jeff.pek
Ok, I see.
Timur.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
