Although the part, marked in blue in the picture, has, to my opinion, degrees of freedom, i cannot rotate it round the main assembly axis, the Z axis.
Maybe it's connected to the 2 holes underneeth it, which i projected?
Or maybe because of the axis i made through the M24 thread?
Solved by blair. Go to Solution.
Without even opening the file, if you have projected holes from another part, this would "ground" the part by making it adaptive to the other part and it would not move by dragging.
