Inventor Forum
I cannot make the Keyway in the hub
6 REPLIES 6
Karol-Or
1005 Views, 6 Replies
I use the Key Design Accelerator, i suceded in making the Keyhole in the shaft, but cannot complete the selection for the hub.
I selected the 2 hub's faces, but am stuck in the third and last selection box for the hub, the Second Reference
6 REPLIES 6
in reply to: Karol-Or
Reference 2 for the hub is the ID (circle).  See attachment.
Karol-Or
How did you select the circle that you showed me in the picture you attached?
It is hidden behind a part, and when i pause over the approximate location-nothing appears, i don't get the ability to choose hidden objects, i don't get the small green square with the 2 arrows, i don't know how it's called
Karol-Or
Even if i turn off visibility of the obscuring feature i still cannot select the circle you showed me
Karol-Or
I want the keyway to be only in the gear, not the circular plate which is around the shaft.
If i select the 2 faces of the gear i cannot select the bore of the gear, only if i select, a one of the faces, the circular plate then the keyway in the circular plate is created.
That isn't my intension.
Karol-Or
It seams i cannot make a keyway in the gear, maybe because it's an iFeature? is it an iFeature?
There is no hole in the gear. Try putting a hole in the gear.
