I use the Key Design Accelerator, i suceded in making the Keyhole in the shaft, but cannot complete the selection for the hub.
I selected the 2 hub's faces, but am stuck in the third and last selection box for the hub, the Second Reference
How did you select the circle that you showed me in the picture you attached?
It is hidden behind a part, and when i pause over the approximate location-nothing appears, i don't get the ability to choose hidden objects, i don't get the small green square with the 2 arrows, i don't know how it's called
I want the keyway to be only in the gear, not the circular plate which is around the shaft.
If i select the 2 faces of the gear i cannot select the bore of the gear, only if i select, a one of the faces, the circular plate then the keyway in the circular plate is created.
That isn't my intension.
