Inventor Forum
I cannot do anything with this problem. Help me please.
13 REPLIES 13
Message 1 of 14
vlad.kuzik.95
585 Views, 13 Replies
I was drawing rectangles (they were green) on a wide box (I saw all of them very well) and then I extruded one of them. As result - other rectangles disapeared. When I was trying to solve this(don't remember how), I made terrible mistake. All rectangles appeared, but then they were yellow. So now I cannot do anything with them, even delete. Help!
13 REPLIES 13
Message 2 of 14
JDMather
in reply to: vlad.kuzik.95
Attach the ipt file here that exhibits this behavior.
Sounds like all you need to do was right  click on the sketch and turn on Visibility.
Sounds like you created a new sketch and Project Geometry.
Have you gone though the Help>Learning Tools>Tutorials and Skillbuilders?
These http://inventortrenches.blogspot.com/p/inventor-tutorials.html
This http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
The CADWhisperer YouTube Channel
Message 3 of 14
You have created more than one profile and when you have extruded the first the others will have disappeared. Right click on the first sketch in the 'Model Browser' and select 'share sketch'. You can then extrude the other profiles you have created.
Hope this helps!
Message 4 of 14
This doesn't help.  But thanks.
Message 5 of 14
vlad.kuzik.95
in reply to: JDMather
It doesn't work. I don't see any changes. It's time to read WikiHelp.
Message 6 of 14
cbenner
Message 7 of 14
vlad.kuzik.95
in reply to: cbenner
Please
Message 8 of 14
karthur1
There are many sketches in this part.  There are several ways to turn off the visibility of the sketches if that is what you are wanting to do.
Tip:
To find the sketch in the browser, right click on an element in chose "Find in Browser".  then right click on the sketch name in the browser and uncheck "Visibility.
You can turn off all sketches in the part from View>Object Visibility.  Uncheck 2D and 3D sketches here.
Post back if you need more help.
Kirk
Message 9 of 14
vlad.kuzik.95
in reply to: karthur1
Thanks. But where I can find my rectangles now.
Message 10 of 14
vlad.kuzik.95
When I close this part and open beck, these yellow rectangles apeared again. How can I protect?
Message 11 of 14
karthur1
Expand the View Node.  Right click and choose "New" to create a new view rep. Name it whatever you want or leave it "View1".  Now turn the visibility of the sketches off and they will stay now.
With the "Master" view rep selected, it is locked and can't be changed, so the changes that you make to the "Object Visibility" are lost when you close the file.  If you turned off each sketch by selecting it and unchecking the visibility, it should stay on/off even with the Master view representation.
Message 12 of 14
JDMather
I think you are going about this the wrong way and doing too much work.
Sketch1 is unconstrained.
Sketch2 is not needed.
Right click on Sketch3 and then hit F8.
Sketch3 is not constrained and already has way too many constraints and dimensions.
You should not need to repeat dimensions - pattern features rather than sketches.
...I gave up after that.  Most of your sketches are not needed and it appears that you should take some time out to go through the tutorials.
What book are you using to learn Inventor?
Have you taken a class?
Message 13 of 14
vlad.kuzik.95
I learn Inventor without books. I'm Ukrainian. The Ukraine use method "tourns and mistakes".
Tags (1)
Message 14 of 14
JDMather
I recommend that you spend a couple of weeks going back through the questions posted here finding as many posted files as you can and examine the problem and solutions by editing the sketches and features.
Have you gone through this
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
Inventor is a professional program and deserves (requires?) a professional level of preparation.
