Inventor Forum
I cannot delete hatch in a drawing
15 REPLIES 15
Message 1 of 16
Karol-Or
24986 Views, 15 Replies
I made a sketch attached to a drawing view, in it made a hatch.
I closed the sketch and the file.
Opened again, after days, activated the sketch, selected the hatch, it turned red, pressed delete but it didn't disappear.
Also on the right click there is no delete option.
When i select the hatch and it turns red, when i press delete or right  click it turns green.
It is strange that when the sketch is closed and i select it in the browser i see the other lines of the sketch in red, but not the hatch.
15 REPLIES 15
Message 2 of 16
CCarreiras
in reply to: Karol-Or
Hi!
To "delete" the Hatch from a Sketch in a drawing view:
  1. Activate "Fill Hatch"
  2. Select again the same frontier
  3. Deactivate the Hatch Button
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 16
CCarreiras
in reply to: CCarreiras
Hi!
To create the plane, you can select the sketch border line and the conical face.
CCarreiras
Message 4 of 16
Karol-Or
@carloscarreiras8703 wrote:
Hi!
You misplaced this answer with a different post
Message 5 of 16
signmeup
This seems to work sometimes but not always. I have a hatch that I cannot delete. The dialog box only wants to add an additional hatch like the visible hatch is not even there.
Product Design Suite 2017, HP Z800 Xeon X5680 @ 3.33GHz x2, CPU x24, 96Gb, Nvidia Quadro 5000
Message 6 of 16
JDMather
in reply to: signmeup
Attach the file here.
Message 7 of 16
signmeup
in reply to: JDMather
Appreciate your offer, but I got around it by deleting one of the lines containing the fill and then redrawing the line.
Message 8 of 16
wayne.lesueur
I just had the same problem. I believe it was due to me sketching over the original hatch boundary. I had a second hatched area that overlapped the first.
By deleting the original boundary (or just part of it) and redrawing, hatch could then identify it.
J
Message 9 of 16
Hunteil
in reply to: wayne.lesueur
I can confirm. This happens when editing a sketch in Sketch Symbols too in my template. I had to delete a edge line for the shape so I could delete the hatch. Double clicking doesn't work and if you select the hatch region tool, then select the hatch area, the deselect option doesn't show. Looks like it's just trying to add more areas.
I also read a the help file and it doesn't really help either. https://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-F9740B4B-DD41-47A7-9A27-87ADC20D681D
I'm pretty sure this has to be a simple fix we're completely overlooking like a setting in Application Options.
Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
Message 10 of 16
johnsonshiue
in reply to: Hunteil
Hi! Does the view have green brackets? If yes, the view is in Raster View mode. The hatch may not be deleteable. Right-click on the view -> Make View Precise. After that, does it work?
If not, please share the files here. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 11 of 16
Hunteil
in reply to: johnsonshiue
No view necessary for this issue.
Attached is the example...I have a circle, a polygon and a sketch symbol. Editing the sketch for the circle and polygon, I can't double click the hatches to edit them. The only way to delete them is by deleting a line. In the case of a circle, the circle is lost.
If you edit the sketch symbol. It's the same issue there.
Message 12 of 16
JDMather
Simply replace the Hatch with None (or desired Hatch).
Message 13 of 16
IgorMir
Alternatively to Jeffrey's suggestion - you could create a new layer, put the hatch on that layer and turn it off. Does the same thing.
Cheers,
Igor.
Web: www.meqc.com.au
Message 14 of 16
Hunteil
in reply to: IgorMir
That's a strange way to get around it. But hey, that'll work. Thank you very much! 🙂
Message 15 of 16
IgorMir
Well, it would be better if the visibility of the hatch in the sketch was handled in the same manner as it is in the section view of a part. But than one would have forgotten how AutoCAD works. 😃
Cheers,
Igor.
Message 16 of 16
Hunteil
@IgorMir yea... consistency isn't a strong suit with this tool it seems.
