Inventor Forum
I can´t see the whole screen
7 REPLIES 7
Message 1 of 8
919 Views, 7 Replies
Hi to everybody
Well I have tried with different resolutions, but even with the highest one 1366x768 I can´t see all the panels on the Inventor screens. It´s like my screen is to small to show all the windows inventor has.
How can I solve the problem?
I attach an image to show the problem, I can´t see what´s under the "point alignment" option, I can´t see the "accept" nor "cancel" buttons.
I tried to search on google and here in the forum but I couldn´t find anything, I hope not to ask something has already been asked before.
7 REPLIES 7
Message 2 of 8
DarrenP
the system requirements say you need at least a 1,280 x 1,024 or higher screen resolution
system requirements are here: http://usa.autodesk.com/autodesk-inventor/system-requirements/
if your resolution is to small not sure if you can do anything about it
DarrenP
Message 3 of 8
in reply to: DarrenP
Ups, I didn´t know that, thank you for your reply. At this moment it´s a nightmare but I have a tip to select the buttons I can´t see, I use the tab button several times and click, sometimes I click cancel, sometimes accept it´s like guessing.
Maybe that helps people with the same problem.
Message 4 of 8
-niels-
Do a google search on "infinite screen", it's freeware that allows for scrolling a virtually larger desktop.
I haven't tried it myself, but maybe it helps.
Otherwise you can always search for other virtual desktop software.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 5 of 8
SBix26
Look carefully at your display settings.  Some graphics systems (Nvidia comes to mind) will have settings that allow you to expand your desktop to a larger resolution than the actual screen. The desktop scrolls when your cursor hits the edge of the screen.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 6 of 8
JDMather
@Anonymous wrote:
..., I use the tab button several times and click, sometimes I click cancel, sometimes accept it´s like guessing.
I used to have that problem in classrooms on data projectors that at the time didn't support high resolution.
My solution was to count the number of tabs needed from a particular location and memorize.
Message 7 of 8
stephengibson76
or use your video settings to rotate the screen, click ok and then rotate it back
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 8 of 8
in reply to: SBix26
Thank you to everybody.
FInally I solved the problem changing one of the display options, I had medium display 125%, I changed it to default 100% and now I can see everything, I´m very happy. I didn´t even know that I had the 125 option activated.
Before that I tried windowslider, unfortunately the desktop is infinite only in the left to right direction, but nothing changed in the top to bottom  direction, so it didn´t solve the problem.
I didn´t test the option of rotating the screen since it is solved, sorry.
See you in other threads friends!
