Inventor Forum
I butt Weld zero distance between parts
3 REPLIES 3
2622 Views, 3 Replies
I want to make an "I butt weld" at two adjacent parts (b=0 distance of two part is zero).
I can not make this. How can I generate this weld type?
you can see ımage at attachment.
thanks
3 REPLIES 3
blair
Just use the Cosmetic weld (produces/leaves an Orange Line). Inventor can't produce a weld with legs in the same plane. Think of it as trying to do a flat weld without any penetration and no gap.
Inventor can't do a Convex weld, only flat face and doesn't understand penetration.
Delta Tau Chi ΔΤΧ
in reply to: blair
Hi Blair,
Thank you for your quick response. Can you send any basic example?
Before your reply, I would have used fake parts for generate distance between fake part & orijinal part. Then I would have hiden the fake part. I will try your solution, but this sounds better.
thanks in advance.
blair
The Orange lines are the Cosmetic Weld, it replicates the volume and mass of a regular weld. It can be placed on any Edge.
Delta Tau Chi ΔΤΧ
