They will always use the Standard.ipt in the directory specified in App
options File Paths tab. Unfortunately there is no way to change it that I
know of.
To get rid of them, I believe you are going to have to change standard.ipt
to not show the planes etc, then delete the iPart children. I would then
start a new assembly and instance in all the children that you had deleted.
Then open the assemblies that originally had these parts in them, ..... I
think it will load them, but say they are different, and you will probably
have to reconstrain them.
Kent Keller
Autodesk Discussion Forum Facilitator
"Alex123" wrote in message
news:33248419.1085414702175.JavaMail.jive@jiveforum1.autodesk.com...
> Hi Kent,
> That is where they are coming from. Now, how do I eliminate them? Do I
make a new standard? But if I do, will I have to import the files again? If
I do import the files again how do I tell them which Standard to use?
> Alex
