You must have at least one key. Make a "other" column named anything and
put some value in it. Make this column a key. Since there is only one row
in this column it will be the only choice in the left hand pane of the
custom ipart placement dialogue.
All iParts, even custom ones, must hat at least one key and they key cannot
be the custom property.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"fredhydro" wrote in message
news:f16b3f4.4@WebX.maYIadrTaRb...
> okay I know how to get the custom parameters done. but I get this message
when I insert the file into an assembly.
> "Detected potentially damaging errors in the table. Too few keys in the
table. Column or cell is tagged as both custom value and as key: #0" All I
have is a suface and I want to thicken it do a desired length.
