I want to incorporate into my rules custom views that will change based on selections from a series of cases.
Looking through the system snippets I found that "Components" accomidates for visibility of a part but nothing I have found will allow for the selection of "View" to be changed from Master to a locked custom view.
In the model tab of the editor it shows View as being available and shows the current view that is selected but when I tried to "Capture Current State" it did nothing.
I want to do this because It would help prevent confusion when looking at the skeleton sketches that I have in this file for condition A... condition B... C and so on..
Is there some way I can do this?
Thanks in advance
If I understand your question correctly, then you will want one of the following segments of code.
For setting the view representation of the part or assembly which contains the rule:
For setting the view rep of a component in an assembly:
I wrote this code to use two user-definded text parameters (ViewRep & SubViewRep). These are multi-value parameters that can have the values seen in the cases.
See the attached assembly and part to see how it works.
Please click "Accept as Solution" if this response answers your question.
Cameron Whetten
Inventor 2012
Yes... I think this will do it but I need to figure out how I can incorporate it into my existing case structure or use is as a seperate rule and use if statements or something.
Thanks!
