Inventor Forum
How would I fully constrain this sketch and create the part?
21 REPLIES 21
Message 1 of 22
Ameldur
1269 Views, 21 Replies
Hi there,
I'm new to inventor and i've been struggling a little bit getting a sketch to match. I've never made this sort of shape before, i dont know how long the arcs are supposed to be and i dont know where to place the R6 circles (between the R108 and R96 arcs) so i can draw an arc that will fully constrain the sketch.
I'd be extremely grateful if you could show me how to do it 🙂
Thank you in advance.
Tags (3)
21 REPLIES 21
Message 2 of 22
in reply to: Ameldur
Did you attach the correct pdf? I'm having trouble figuring out which circles/arcs you're talking about, looking at the drawing.
Message 3 of 22
jddickson
Here is the finished model with constraints and dimensions. The only dimension that I could not find was the height of “Extrusion 7”. You can turn on the constraints so you can see them. I hope this helps.
Message 4 of 22
mcgyvr
in reply to: jddickson
Sure looks like the OP posted the wrong file..
Message 5 of 22
JDMather
You might want to zoom in here real close (Sketch 6).
For example on how not to do a sketch.
Message 6 of 22
JDMather
in reply to: JDMather
Also,
this hole is the wrong size in the attached example.  Should be a tapped M4 hole (which is not 4mm).
Message 7 of 22
Ameldur
Wow, i added the wrong file. So many people have replied, so sorry!
Thanks for the replies! Again, really sorry about that 😕
Attached the correct file now 🙂
Message 8 of 22
There we go! 🙂
Message 9 of 22
JDMather
Now attach your *.ipt file to show what you have attempted so far.
Message 10 of 22
Ameldur
I deleted my .ipt file as i couldn't manage to draw it.
I started from the top and drew the two arcs (R108 and R96), offset copy'd them both inwards and constrained the innermost ones by 6 and the two outer ones by 3 like on the drawing. I tried several constraints to make them line up but I didnt manage it 😕
I don't understand how long the arcs are supposed to be either, or where to place the R6 arc that connects the R108 and R96 😞
Message 11 of 22
JDMather
Try again.
Message 12 of 22
JDMather
Sketch vertical center line from origin.
Sketch the two arced "slots".
Sketch the two angled lines.
Add Symmetry constriant selecting the two angled lines and then the center line.
Add your dimensions.
Message 13 of 22
JDMather
...and wait for it.... the next question.  (see attached)
Message 14 of 22
jddickson
Parts not done right. The Fillets need to be added...
Message 15 of 22
I would use a skeleton of construction geometry, sketching solid lines and arcs on top, leaving any fillets/blends for a second operation after the intial extrusion.
Note, however, that all fillet radii from your drawing (and your part thickness) all appear to be off by a factor of +2.  The part pictured above is as-specified by the drawing but with the thickness halved to 2MM.
Message 16 of 22
Ameldur
Like this JDMather? 🙂 I noticed you only have one dimension with 40 degrees, how did you do that? I keep getting two,
Message 17 of 22
JDMather
You must have missed the instruction to attach your *.ipt file here.
Message 18 of 22
Ameldur
Sorry, hehe 🙂
Attached!
Message 19 of 22
Part File (for inspiration) attached; note that this file exhibits 1.5MM raddi on major fillets and .25MM minor fillets, as well as a 2MM thickness.
Message 20 of 22
Ameldur
Thanks Nathan!
Why do you have incorrect fillets and 2mm thickness? Just because you can or is there something wrong with the drawing? 😮
