Inventor General
J0mppe
Message 1 of 10 (2,468 Views)
How to use .stl and other mesh files in Inventor?
2468 Views, 9 Replies
09-07-2011 05:35 AM
We are trying to use 3d scanned data in Inventor to help our design process. We don't need perfect and good looking 3d scanned models ready to produce, but we need some accurate measurements from holes and faces that we can use to design our own products.
So mine problem is: How I can get those scanned meshes to Inventor that I can get some dimensions from it, project some geometry to my sketches, add some constraints between scanned surface and mine designs, etc...?
I have tried some Add-Ins like Sycode's STLImport and Sycode's software called Mesh To Solid to get those mesh files open and I can open those "converted" files in Inventor, but those are only some kind of surfaces called Composite or Surface which consist of tiny triangles.
Mark_Flayler
Message 2 of 10 (2,448 Views)
Re: How to use .stl and other mesh files in Inventor?
09-07-2011 06:24 AM in reply to: J0mppe
...and that is about the quality you will get from any translator considering stl files are HIGHLY faceted surfaces and not quite the same as what the Inventor kernal uses.  I have a free add in I have been using for some time for this visual representation, but if you want true scanned and usable geometry you will probably have to go through an intermediatary like Geomagic first.
Here is a good look at the process:
http://www.youtube.com/watch?v=c7sMf7eDC_w
Mark Flayler Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
J0mppe
Message 3 of 10 (2,413 Views)
09-09-2011 12:17 AM in reply to: Mark_Flayler
So there is no way to do solid models or "simpler surfaces" from mesh file in Inventor? Geomagic would be a nice software, but I think it's too expensive... So I'm looking for cheaper and simpler way to do this job.
Mark: Where did you get that free Add-In and what's the name of it?
Employee
KevinLi-Autodesk
Message 4 of 10 (2,409 Views)
09-09-2011 01:24 AM in reply to: J0mppe
Hi joni,
Very appreciate for your report about this, unfortunately this is a known limitation with the Inventor at the moment and we have already noticed this requirement and will do some enhancements in future release. I will log your issue into our tracking database and it will increase the possibility of this issue being enhanced in the future.
Kevin Li
SQA Engineer
Kevin-Hongyuan Li
Quality Assurance Team
Mark_Flayler
Message 5 of 10 (2,398 Views)
09-09-2011 04:25 AM in reply to: J0mppe
http://modthemachine.typepad.com/my_weblog/2009/07/working-with-stl-and-obj-files.html
J0mppe
Message 6 of 10 (2,394 Views)
09-09-2011 05:51 AM in reply to: Mark_Flayler
I have tried that Add-In too, but I didn't get it to work. When I pressed import button, picked up the .stl file and tried to import it nothing just happened and I don't know why?
knattagh
Message 7 of 10 (1,795 Views)
12-24-2012 05:30 PM in reply to: J0mppe
The link below can tell you exactly how to go froma  mesh to a solid in ivnentor.
Let me know if it works and/or if you have any other questions
-Khash
knattagh
Message 8 of 10 (1,794 Views)
12-24-2012 05:30 PM in reply to: knattagh
New Member
edwardneumann
Message 9 of 10 (979 Views)
10-17-2013 01:33 PM in reply to: J0mppe
Is there a way to import an STL file into Inventor 2014?  I need it to be a solid model, to add or subtract profiles to it.
I checked out the mesh converter; I downloaded it but it says it needs Inventor 2013.
Any help would be appreicated.
Thank You.
JDMather
Message 10 of 10 (969 Views)
10-17-2013 03:04 PM in reply to: edwardneumann
There is a 2014 version available for subscription customers here
http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com%3ameshen...
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
