How to use different configuration of parts made with iLogoc in assembly? I want to have equal part with different configuration. I have a problem with the equal files.
How to use different configuration of an assembly made with iLogic in assembly?
Hi!
I don´t know if i am understanding your issuen but...
If you have diferent part's configuration driven from ilogic rules, you have to place the ilogic part (only one part) in the assemblys and share the parameters betwen the part and the assembly.
If you share the parameters, you can control the part's configuration inside the main assembly changing the shared parameters.
Also you can program in ilogic diferent part numbers for part, for diferent configurations.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
when i use ipart and iassembly i haven't this problem becouse I can choose several configurations of part in assembly.
