Inventor General
Active Member
Message 1 of 7 (871 Views)
Accepted Solution
How to use content center?
871 Views, 6 Replies
06-22-2012 03:12 AM
Good morning guys,
I'm using a student version of inventor 2013, and i'm trying using the content center for add bolts at my project, but all the components are unable for my use, because everything are marked as read only.
How can i do for use these components?
and other question, how can i create account at vault?
best regards
*Pro
sbixler
Message 2 of 7 (858 Views)
Re: How to use content center?
06-22-2012 05:18 AM in reply to: julianoalvesde
Content Center libraries delivered with Inventor are read-only, and that cannot be changed.  Content Center components placed in your assembly are also read-only, but this is only because the default location where the files are placed is defined as read-only by your project.  If you move them to another folder, they are editable.  But normally you shouldn't need to do that.
*Expert Elite*
Cadmanto
Message 3 of 7 (856 Views)
06-22-2012 05:29 AM in reply to: julianoalvesde
Sam explained the CC question well.  As far as getting an account with vault, I would say you should talk to an administrator at your school about getting access to the vault.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
*Expert Elite*
Message 4 of 7 (849 Views)
06-22-2012 05:38 AM in reply to: julianoalvesde
How are you trying to place the components?
If you place as Custom they are taken out of the CC and placed local.
Why do you need Vault as a single user seat?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 5 of 7 (772 Views)
08-21-2012 07:38 AM in reply to: julianoalvesde
I have a desktop CC installation right out of the box for 2013 and I can't place a bolt or anything else from the CC.  All my folders are in order, but I always get the 'Query to the server failed' message.  I know the standard content center files are there, I can see them, the size, etc, and in the right folder (\programdata\Autodesk\Inventor 2013\Content Center\Libraries\) and I set the project path for content center to the same folder, and left the default \..\..\Content Center Files\R2013 as my application settings File tab setting.
I made sure I was NOT using Vault and that I was using desktop. Stumped in Georgia...
*Expert Elite*
Message 6 of 7 (767 Views)
08-21-2012 07:55 AM in reply to: daviswe
Attach your project *.ipj file here.
*Expert Elite*
Mark_Flayler
Message 7 of 7 (749 Views)
08-21-2012 12:35 PM in reply to: JDMather
Go to your Application Options and on the Content Center Tab, change from Vault Server to Desktop Content.  That will stop the system from quering a Vault that really isn't there and look to your ProgramData directory instead.
Mark Flayler Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
