Inventor Forum
How to use content center?
12 REPLIES 12
Message 1 of 13
2336 Views, 12 Replies
Good morning guys,
I'm using a student version of inventor 2013, and i'm trying using the content center for add bolts at my project, but all the components are unable for my use, because everything are marked as read only.
How can i do for use these components?
and other question, how can i create account at vault?
best regards
Tags (2)
12 REPLIES 12
Message 2 of 13
SBix26
Content Center libraries delivered with Inventor are read-only, and that cannot be changed.  Content Center components placed in your assembly are also read-only, but this is only because the default location where the files are placed is defined as read-only by your project.  If you move them to another folder, they are editable.  But normally you shouldn't need to do that.
Message 3 of 13
Cadmanto
Sam explained the CC question well.  As far as getting an account with vault, I would say you should talk to an administrator at your school about getting access to the vault.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 13
JDMather
How are you trying to place the components?
If you place as Custom they are taken out of the CC and placed local.
Why do you need Vault as a single user seat?
Message 5 of 13
I have a desktop CC installation right out of the box for 2013 and I can't place a bolt or anything else from the CC.  All my folders are in order, but I always get the 'Query to the server failed' message.  I know the standard content center files are there, I can see them, the size, etc, and in the right folder (\programdata\Autodesk\Inventor 2013\Content Center\Libraries\) and I set the project path for content center to the same folder, and left the default \..\..\Content Center Files\R2013 as my application settings File tab setting.
I made sure I was NOT using Vault and that I was using desktop. Stumped in Georgia...
Message 6 of 13
JDMather
Attach your project *.ipj file here.
Message 7 of 13
mflayler2
in reply to: JDMather
Go to your Application Options and on the Content Center Tab, change from Vault Server to Desktop Content.  That will stop the system from quering a Vault that really isn't there and look to your ProgramData directory instead.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 8 of 13
in reply to: SBix26
But i can,t change its loction
Message 9 of 13
Mark.Lancaster
@Anonymous
Welcome to the community...
Can't change what?   There's not much to go on here with your posting.  What are you trying to accomplish?   Also include Inventor version..  Smiley Wink
Mark Lancaster
Message 10 of 13
Dear Sir,
I am using Autodesk Inventor Professional 2017. In assembly, When i wants
to add fastener Its show a error. *Content Center Server query failed.*
* Thanks & Regards,*
* Faisal Shahzad*
Asst. Engineer Mechanical
* faisal10338@gmail.com *
*Mob (Qatar): +974-33477781 <%2B974%2033844038>*
*Ammico Contracting Co. W.L.L Doha, Qatar*
[image: Description: Description: Untitled]
*ISO 9001:2008 Certified - Geotechnical Specialist Contractors for
Foundation Engineering*
*P**Please consider the Environment and don't print this email unless you
really need to*
Message 11 of 13
Mark.Lancaster
@Anonymous
What type of content center is this?  Desktop or managed through your Vault?
Does this happen on any parts you place from Content Center or just certain ones?
Mark Lancaster
Message 12 of 13
Dear Sir,
Please find the attached file for your assistance. when i click
to add fastener then no file shown.
* Faisal Shahzad*
really need to*
Message 13 of 13
Mark.Lancaster
What attached file?  Nothing is attached..
Mark Lancaster
