I've spent 10 minutes googling and can't find an answer. I've made a mold, and the cavity is almost invisible, both in the .iam and in the _CV_1. I just want to make it opaque (either place) so I can examine it.
I've found lots of explanations of how to make parts transparent, but none for how to remove transparency. I've tried right-clicking on everything I can think of. I went into the styles editor, but it only seems to do lighting and text in 2014.
I would turn off transparency in the "create core/cavity" dialog, but all the appearance controls seem to be disabled and I've never been able to figure out how to enable them.
ARGH!
Thanks.
Solved by WHolzwarth. Go to Solution.
I did it this way:
- Open *_CV_1.ipt
- Apply different color than Standard
Walter
Walter Holzwarth
Thank you. In mine the pulldown contains "Default" and I needed to change it to something else. I could have sworn I tried that before.
