Inventor General
Distinguished Contributor
Karol-Or
Message 1 of 2 (84 Views)
How to temporarily disable point alignment in sketches
84 Views, 1 Replies
10-28-2013 04:38 AM
In application options there is the point alignment option which infers alignment between endpoints of newly created geometry and points of existing geometry.
Is there a shortcut that disbles it temporarilly while sketching?
Is there a list of all the shortcuts?
Distinguished Mentor
ccarreiras
Message 2 of 2 (80 Views)
Re: How to temporarily disable point alignment in sketches
10-28-2013 05:01 AM in reply to: Karol-Or
Hi!
Yes, you can press "Ctrl" to avoid constraint inferences while you sketching. Release "Ctrl" to continue having inferences.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
