Inventor Forum
How to stop updating my drawing from the linked part
4 REPLIES 4
2259 Views, 4 Replies
Hello everybody !
I am pretty sure there must be an easy way to solve my problem, but I can't seem to find a solution yet.
So I am using Inventor LT 2012 in a small company that makes conveyor rollers. Most of the time we make the same roller with only different values to the variables. So I decided to make a part with the parameters in an Excel sheet:
A customer call us, and they want a roller with x,y,z dimensions, I put in in Excel and the drawing is ready.
But, when I need to make a second drawing of that roller with different dimensions, the first one also change.
Is there any way to keep a drawing fix when it is done ? If possible, only making a dwg for each customer without having to make an ipt and excel sheet for each drawing would be awesome !
Hope I explain the problem clearly.
Thank you in advance for any idea.
Max Otis
4 REPLIES 4
blair
Try:
Tools>Document Settings>Drawing>Defer Upates
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
Wonderful !
Exactly what I was looking for.
Thank you very much !
You really need to copy the whole data set, lock stock and barrel.
I outlined some way to do this in this post:
http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
Let me know if you find it helpful,
Paul.
Thank you for your help Paul,
but as mentioned in the initial post, I am using the LT version of Inventor, so I make all my products in an ipt. file (they are fairly simple anyway)
Max Otis
