Inventor General
Employee
Message 11 of 12 (171 Views)
Re: How to simulate motion-rotation-translation?
09-19-2012 11:25 AM in reply to: cwalker41
Hi cwalker41,
  JD is correct, you can use 2D contacts in Dynamic Simulation (which is included in Inventor Professional, which you should have with your Educational license).
  However, you could also accomplish what (I think) your're after using assembly contact set and drive constraint.
  I created a couple of constraints, one that will keep the shaft hole centered in the slot.  The other mates the axis to a plane with will move the mobile part across the plate.  The second one is the one you drive.
  If you open the assembly, right-click on Mate:3 in the browser => Drive constraint => press the play button.
  Hope this helps...
Best regards, -Hugh
[Edit: added recording of driven constraint]
Hugh Henderson
Simulation QA Engineer
DLS
Employee
Message 12 of 12 (159 Views)
09-19-2012 01:06 PM in reply to: henderh
I forgot to mention that before you drive the constraint or drag the mobile part, you'll need to activate the assembly contact solver (Inspect tab => Interference panel)
Hugh Henderson
DLS
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
