In V2013 i make a 3D sketch and choose spline.
I don't see the precise input toolbar and don't know how to bring it
Solved by JDMather. Go to Solution.
I recommend that you forget you ever saw Precise Input (there is almost certainly a better way), but to get to it:
Start a new 3D sketch
Start the Line command
Click on the Draw ribbon down arrrow
(see attached)
Post screen shot similar to the screen shot I attached.
Have you installed Service Pack 2 and the Update for SP2?
If a different user logs into this computer does it work?
If it does, it mean that you have a slightly corrupt user profile,
Please send us an update.
Thank you.
