I'm kind of a newb in this area, so i apologize in advance if my question seem a bit obvious.
Where i am working, i am the person with the most experience with inventor related topics. So i was put in charge of modifying The commun library of our content center. Later today, i found out that one of our draftmen played around our library and modifying some of the preset that i setup.
My question is: What can be done to limit access (Putting it at Read-only) to certain library for certain users without limiting my own access?
Also, i'm pretty sure its not possible but ill ask anyway, is it possible to know who modify those library and when?
Sorry for the bad english, it is not my first language.
I'm using Vault
Thank you
Solved by Cadmanto. Go to Solution.
Are you taking about using the content center editor to create a custom content center? I know you used the word "Library", but I just wanted to clarify.
If you are using vault you can change this others users login user level to control this.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Yes, i was talking about a custom content center.
Thank you very much, i found the global settings for users in our software Vault.
It did exactly what you suggested.
