Hello all,
We are using inventor 2014 LT in our work place and just recieved it. We are a production company that often makes many variations of a single part baised on the indivual job. I was wondering if there was a way to save one part file with multiple configurations so when you pull it into assembly file you select the configuration you want and then place it on the assembly.
Any help appreciated,
Thanks!
Solved by Cadmanto. Go to Solution.
Yes, it is possible.
They are called iparts and iassemblies.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=10921207
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=15018021
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
.... I'm not sure any of that is available in Inventor LT.
The CADWhisperer YouTube Channel
It's there for 2013. http://wikihelp.autodesk.com/Inventor_LT/enu/2013/Help/0305-Autodesk305/0467-Parts467/0540-iFeature5...
Is it fair to assume it is there for 2014?
...good to know iParts are avialable in LT.
You also had a link to iAssemblies?
No, but from what I have researched it looks like iassemblies are available in LT as well.
