I want to reset the number for the sketches, extrusions, etc. in the browser tree of my template file to start with 01 instead of sketch48 and extrusion69.
I also want to reset the model parameters to start with d0 instead of d485.
The attached image show an example of a simple cylinder that I created from my .ipt template file. (See the attached image.)
Not sure of there is a way other then doing a slow double click on them in the browser and manually renaming them.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I forgot to add in my first posting, there is no attachment in your original post.
Are you saying if you start a new file that it doesn't start with first dimension d0 and first sketch as Sketch1?
If so, have you edited your template?
Have you done a Save Copy As Template?
Are you saying if you start a new file that it doesn't start with first dimension d0 and first sketch as Sketch1? (yes)
Attached is the an image. I accidently left it off my first post.
Attach your Template file here (do not open it in Inventor).
