Hello I am developing a web app ASP.NET MVC 3, which will read the properties files of Inventor (dwg, idw, ipt, iam). Read the properties of these files is by using objects Apprentice Server, which provides Autodesk Inventor View 2012. Connection objects is done through the library RxApprentice.tlb.
Code is shown below:
public ActionResult Index ()
try
ApprenticeServerComponent appServerComponent = new ApprenticeServerComponent ();
ApprenticeServerDocument apprenticeServerDocument = appServerComponent.Open (FileName);
var ListPropety = apprenticeServerDocument.PropertySets ["Design Tracking Properties"].
Cast <Property> (). ToList ();
var CollectionProperty = ListPropety
. Where (x => x.Name! = "Thumbnail")
. ToDictionary <Property, string, object> (
property => property.Name,
property => property.Value
ViewBag.CollectonProperty = CollectionProperty;
catch (System.Runtime.InteropServices.COMException ex)
ViewBag.ComException = ex.Message;
return View ();
While debugging applications on Web-server - IIS Express 7.5 development environment Visual Studio 2010 application runs without errors.
After publishing a Web application on IIS 7.0 the following error: "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))ยป.
A tried: change User Account Control Settings, and set permissions to configuration DCOM objects in Component Services - no results.
Is it possible to read the file properties Inventor of Web applications, and how to do it? Help solve the problem. Thanks for any help!
Hi prixodkomv,
You might have better luck asking questions and searching for answers of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
