Inventor General
Member
Message 1 of 4 (198 Views)
How to put a hole in a curved piece?
198 Views, 3 Replies
06-22-2013 07:35 PM
In the attached file I have a curved piece of sheet metal made with the contour flange tool. All I want to do is put a hole in the center of the sheet.
Thanks for your help!
blair
Message 2 of 4 (192 Views)
Re: How to put a hole in a curved piece?
06-22-2013 08:37 PM in reply to: larzlorocks
You should post the version you are on, saves people downloading your file and producing a solution to your problem that you wouldn't be able to open and view.
Just create a work-plane from one straight end edge to the other. Project your side edges, create a construction line from middle side to middle side and place your circle center point on the middle of the line.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Message 3 of 4 (166 Views)
06-23-2013 06:52 AM in reply to: larzlorocks
Actually, your question might be more complex than you realize (or than the "solution" Blair led you to).
There are more considerations on a sheet metal part.
Do you want the hole to be round in the flat or in the folded part (can't be both)?
When will the hole be made - before or after the part is rolled.
Usually the hole does not need to be perfectly round in the rolled part, so it is drilled or punched in the flat.
In that case, click Unfold (follow the prompts) create the Hole feature and then Refold.
If you need the hole to be perfectly round in the rolled part - it becomes just a bit more complex.
Again, when will the hole be added to the part.
If added in the flat stage it will not be circular - so will need to be punched, burnt or water-jet cut.
The easiest way to do in Inventor is to trim a surface and then Thicken/Offset.  This will also return the shape you need in the flat pattern.
A final option is the hole is made after rolling (in the actual manufacturing process - so no hole in the flat pattern).
If that is what you are after, post back for solution.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Member
Message 4 of 4 (149 Views)
06-23-2013 01:53 PM in reply to: JDMather
Huh, you're completely right. The hole will be made after the sheet is bent so that it is completely circular and will allow a cylinder to be put in. At this point the radius doesn't really matter.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
