Inventor Forum
How to prevent a circular body from rotating
2 REPLIES 2
Karol-Or
290 Views, 2 Replies
In a weldment assembly i place a symmetric, circular part, but later i want to drill holes in it, and i am afraid that i will accidentally rotate it.
Can i place a constarint that prevents it from rotating? there is no such possibility.
I can ground the part, but i don't like it since if there are modifications they might not be applied (i don't have experience in grounded parts)
2 REPLIES 2
-niels-
in reply to: Karol-Or
You can use constraints on the origin planes to prevent rotating.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
CCarreiras
Hi!
I usually apply angle constrains to prevent rotation. Apply between the cilinder's origin plane with another face or planes's part.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
