I'm modeling a temperature gauge and would like to have glass over the gauge so the inside is visible. I can easily do this with an assembly, but I'm wanting to do this with a single part. I tried to derive a new part from the assembly, but the transparent part turns solid so nothing inside is visible. Is it possible to do this?
I've include pictures of what I want and what I end up with. Thanks in advance!
Solved by mpatchus. Go to Solution.
Hi
The transparent texture cannot be apply to single body in multibody part
This is limitation
@Anonymous wrote:Hi
This is limitation
I've just tried this twice. The first time it didn't work, the second it did. I don't know what the difference is.
Hi! The transparent color cannot be applied to Features or Faces on a given solid body. It is because exposing the back faces of non-transparent surfaces would make the view very confusing to look at. You can create a separate body just for the glass piece and make it transparent in the part
Thanks!
You have to create a new seperate body to do this, just like rdyson showed in his picture.
A seperate solid for the glass works fine.
Hi
sorry for the bad information
i would it mean that's for feature like Johnson point
Just make sure as you extrude the bodies in a multibody part to select the new body selection button (highlighted).
Then select the solid body in the browser and apply color to it, or in your case glass material.
I cannot seem to get just one extrusion to be transparent in my model. Can you help? I would like just the body (extrusion 4) to betransparent.
dwing
You need to create as multi-body solid as already discussed in this thread. See response #8.
Your sketches aren't constrained (yet a perfect dimensions if I add them - did you delete them, if so why)?
Workplane1 is not needed.
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Thanks for the quick reply J. D.
The model I have was originally a Pro/E .step file. I used Inventor Feature Recognizer to create the .ipt, that is why the sketches are not constrained.
It seems like I would have to re-create the model from scratch in order to 'do it correctly'. Thanks anyway.
dwing
Product Designer
Young & Franklin, Inc.
Specialty Fluid Controls
You have the sketches - so you wouldn't need to completely start from scratch.
Simply change the Extrusions to New Solid.
OK, J. D. thanks again. What I didn't catch on to is that once the Extrusions are set to be New Solids, you have to edit the Solid's properites, NOT the individual extrusions. (I think.)
So, I set the Extrusion property to "As Body" and the corresponding Solid to the appearance I wanted. (Although it seemed like I had to try a whole bunch of times before it 'magically' worked. Even then I'm not really sure that what i did.)
Thanks again for your help, and I hope this thread helps others.
dwing.
Product designer
Young&Franklin, Inc,
