Like in the picture, and what is the name, if exists, to such dimensions
Solved by Cadmanto. Go to Solution.
Solved by CCarreiras. Go to Solution.
Once you have all of your dimensions created, tag them all (holding down the Ctrl key) and RC and select as shown below. This will snapp them all in line with each other.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!! :smileyvery-happy:
