Inventor General
Active Member
Message 1 of 2 (172 Views)
How to make attached part Adaptive?
172 Views, 1 Replies
12-01-2012 07:28 AM
When I create part .ipt directly in assembly .iam, I can make it adaptive. I'm doing the projection of geometry. Detail goes adaptive. Geometry appears as a link.
But if I put in the assembly finished parts or remove part created in the assembly, and then insert it back, the adaptability of parts did not get to create. Then the projection geometry inserts usual nonadaptive geometry without reference.
Can I make a finished part adaptive, without creating a component at the place in this assembly?
Thank you!
Valued Mentor
Message 2 of 2 (158 Views)
Re: How to make attached part Adaptive?
12-01-2012 05:39 PM in reply to: bodich
Try to open a part and un-check Adaptively Used in Assembly box in Document Settings-->Modeling.
Please see the attached picture for clarity.
Igor.
Web: www.meqc.com.au
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
