Hello everybody, I'm doing a project for school and I built a shock absorber. I've already done about 50% of the project, but I'm havin a problem with the spring, I can't make it move. And I don't want to use any animations, I want to be able to move the part manually. Also there is a preload force applying on the spring, so I have to move (preload) it for x mm to the left. How do I do that? I've attached a photo and the project files for you to understand what I need.
1. How do I make the spring moveable
2. How do I set an offset between the 2 plates, for the spring to be preloaded
Open "forum" file from the project folder to see the part.
Thank you.
Solved by CCarreiras. Go to Solution.
Hi!!
I will make your spring in Inv 2014 and i will sent you, ok?
I think it is a very complcated to explain you how to do it... it's better you explore the parts.
See you soon...
HI!
https://screencast.autodesk.com/Embed/Timeline/d6b1add8-e775-4394-921b-1054b8fb71ab
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
