Inventor Forum
How to make a coil
7 REPLIES 7
Message 1 of 8
1826 Views, 7 Replies
How to make a coil
Hi boys,
I have a question, need help sure
How I would wrap/coil a tape around this attached picture?
You see the rounded edge, it's not fully circle
7 REPLIES 7
Message 2 of 8
Cadmanto
Check out this link and see if it helps you.
http://www.youtube.com/watch?v=q4htnkH2H1k
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
CCarreiras
Hi!
I d'ont know any tool to make this automatically.
Most of all, 2D and 3D sketches ... with a final sweep.
I made one manually, just for curiosity... it works well... see the file attached..
Note: You can went to the Parameters table and operate some changes.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 4 of 8
in reply to: CCarreiras
Hi Carlos,
YES.
It is exacly what I were looking for, Thank you very much.
But unfornitutly I couldn't open the ipt, I have Inventor 2012.
Could you please make it on IV2012.
Regards
Sohaib
Tags (3)
Message 5 of 8
I forget to mention, the rectangular that I have its end not like his start.
Start with rectangular dimension for example 4 x3 but it end with smaler dimension for example 3 x 2.
How would the rectangular now folow the shape?
Sorry for this complexation
Regards
Sohaib
Message 6 of 8
JDMather
Loft or Extrude with taper the "tube" as a surface body (increase size by radius of swept feature).
Coil line as surface body.
3D sketch to find Intersection Sweep Path.
Workplane perpendicular to beginning of Sweep Path.
Create profile and Sweep.
Message 7 of 8
CCarreiras
HI!!
I dont have 2012 version installed.Smiley Frustrated
I left you the browse three to help you following the construction of the coil.
The steps are described in JD post above.
CCarreiras
Message 8 of 8
Hi Carlos,
Thank you for your efforts and time.
JD, Thank you too
Many thanks.
Regards
Sohaib
