Inventor Forum
How to make Exploded View Trail Lines Exempt from a View Break Out
4 REPLIES 4
OlliC
917 Views, 4 Replies
I have made an explded view and placed it an a drawing. I would like to view inside one of the bodies to help show where the exploded internals sit, however when I do a break out of the body the trail lines from the exploded internals also get sectioned. Is there a way to control the sectional properties of a trail line? So far I havent found one.
4 REPLIES 4
OlliC
in reply to: cbenner
Cheers Chris,
I'm using Inventor 2014.
I've attached a picture, I would like the trail lines to extend up to the O-Ring Grooves inside the body. They do on the presentation model, but get removed during the break-out of the body in the sketch. I've tried moving the O-Rings back before moving them down in the hope that the trail line would be behind the break out limit, this hasn't seemed to work.
Olli
cbenner
in reply to: OlliC
Hi,... I've been playing with this in 2013 and I haven't seen any real way of changing the way the trail lines display after cutting a section.  I don't use exploded views often, however, so I'm not going to say there ISN'T a way.  Sorry I couldn't be more help!
OlliC
No worries! Thanks for your reply. I will just sketch them on.
