In sketches i can see the names of the dimensions, the parameters, but if i have a few extrusions, can i know which parameter governs the height of the extrusion only according to their content?
Solved by harco. Go to Solution.
Edit the extrusion.
Hover the cursor over the value box, a tool tip will show the dimension name.
I you don't like the name type a new name in the box equals the value and it will be renamed on the fly, e.g. Length=100, this will then be more obvious in the parameters dialogue.
You can also RMB on the extrusion and show dimensions then they will appear in the graphics window.
