Trying to find a way to increase the size of the 3D spline nodes so that they can be seen easier. Is there a setting to control this?
Thank you,
Solved by JDMather. Go to Solution.
Tools>Application Options>General tab>Annotation Scale
you might also toggle them to Center Points (upper right corner of screen).
The CADWhisperer YouTube Channel
