Inventor Forum
How to get parts/assemblies to update inside an assembly
3 REPLIES 3
327 Views, 3 Replies
I have a large assembly that has lots of parts and assemblies inside it.  I'm trying to set different materials and apperance for it so I can do some rendered images.  Only problem is that when i go to the orignial file to update the apperance of the parts it will not update the apperance inside the large assembly file.
I tried updating the drawing but that doesn't help.  I also tried saving both files, closing them and then reopening the large assembly file and that didn't work either.
3 REPLIES 3
Curtis_Waguespack
Hi MicahelASC,
In order to change the appearance, you will need to set a View Representation active in the browser. I suspect that this is what is causing the issue, but I'm only guessing. If this is not the issue, could you provide a screen shot showing the browser for clarification?
About View Representations:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-9A49CDC1-4DC7-4462-81D7-E18B8339DE0F
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
I created a new view, how do I tell it to update the apperances I assigned the subassemblies and parts?
Just kidding I figured it out.  I had to click remove apperance overrides.
