Inventor General
Message 1 of 4 (104 Views)
Accepted Solution
How to get parts/assemblies to update inside an assembly
104 Views, 3 Replies
02-03-2014 12:28 PM
I have a large assembly that has lots of parts and assemblies inside it.  I'm trying to set different materials and apperance for it so I can do some rendered images.  Only problem is that when i go to the orignial file to update the apperance of the parts it will not update the apperance inside the large assembly file.
I tried updating the drawing but that doesn't help.  I also tried saving both files, closing them and then reopening the large assembly file and that didn't work either.
*Expert Elite*
Curtis_Waguespack
Message 2 of 4 (98 Views)
Re: How to get parts/assemblies to update inside an assembly
02-03-2014 12:38 PM in reply to: MicahelASC
Hi MicahelASC,
In order to change the appearance, you will need to set a View Representation active in the browser. I suspect that this is what is causing the issue, but I'm only guessing. If this is not the issue, could you provide a screen shot showing the browser for clarification?
About View Representations:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-9A49CDC1-4DC7-4462-81D7-E18B8339DE0F
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 3 of 4 (87 Views)
02-03-2014 01:00 PM in reply to: Curtis_Waguespack
I created a new view, how do I tell it to update the apperances I assigned the subassemblies and parts?
Message 4 of 4 (86 Views)
02-03-2014 01:03 PM in reply to: MicahelASC
Just kidding I figured it out.  I had to click remove apperance overrides.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
