Inventor Forum
How to get part status in ilogic (inv 2011)
4 REPLIES 4
yannick3
1166 Views, 4 Replies
Hi
How to get part status in ilogic ? ex:relaesed, pending, work in progress
i would like to set up a rule with this iproperty and i can find it, all except this one.
Some people can help me please
thank
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
4 REPLIES 4
MjDeck
in reply to: yannick3
Here's code to read that property.  It's a bit tricky, because it gives you a numeric value code instead of a text string.
designState = iProperties.Value("Status", "Design State")
If (designState = 1) Then
  MessageBox.Show("Design State: WorkInProgress", "iLogic")
ElseIf (designState = 2) Then
  MessageBox.Show("Design State: Pending", "iLogic")
ElseIf (designState = 3) Then
  MessageBox.Show("Design State: Released", "iLogic")
Mike Deck
Software Developer
Autodesk, Inc.
yannick3
Hi
Thanks a lot for your answer
i've another question, It is possible to set the printer with ilogic's print document snippet
if i've not setup the printer in the cad session the snipet take the default MSwindow printer
how to set-up it permanently(from ilogic rule) and keep the default MSwindow printer setup?
Thank
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
MjDeck
Here's the snippet with a line added to select the printer.  You can find out more about the PrintManager class in the API help, which is available on the Inventor Help menu under
Additional Resources -> Programming Help
oPrintMgr = ThisDoc.Document.PrintManager
oPrintMgr.Printer = "PDFCreator"
oPrintMgr.ColorMode = kPrintGrayScale
'oPrintMgr.ColorMode = kPrintColorPalette
oPrintMgr.NumberOfCopies = 1
oPrintMgr.Orientation = kPortraitOrientation
'oPrintMgr.Orientation = kLandscapeOrientation
oPrintMgr.PaperSize = kPaperSizeCustom
oPrintMgr.PaperHeight = 11
oPrintMgr.PaperWidth = 8.5
oPrintMgr.SubmitPrint
Mike Deck
Software Developer
Autodesk, Inc.
yannick3
Thanks again
That's give for me a lot of work to set up my rule
Yannick
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
