Are you asking how to create a drawing of the part with multiple views? I'm not clear on what you want to do?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
In the real world a part is a part
an assembly is an assembly
a drawing is a sheet of paper with 2D views to represent the 3D part or assembly.
A drawing is not a part or an assembly - it is a sheet of paper.
The people out on the shop floor have no trouble understanding this concept.
In Inventor a part is an ipt file.
In Inventor an assembly is an iam file hyperlinked to ipt files.
In Inventor an drawing is an idw or dwg file with views hyperlinked to the ipt or iam.
For some reason, AutoCAD users have trouble with this concept and exhibit undue concern about file managment. (create a folder or use Vault - it is all 1s and 0s)
But JD It's even worse than that is, it's their managers who had a had time even understanding Acad. Ask most Acad users or managers what's "Paper space vs model space " and when did Autodesk bring out that concept around 94. Or try and explane to an old Autocad manager that the model is like the King as compared to the drawing and all things come from the model. Even as our end product is paper if you don't keep and save the models there is no drawing for the next change. Or the lack of understanding of how important that the parts list is tn the drawing, weather or not you actually put it on the paper or off to the side because you're company doesn't use drawing parts lists.
Hi.
First of all, I am very sorry for a very late response, which is due to some difficultiy in accessing the net in the place I am currently staying(temporarily).
By the way, what I wanted to know is that I have modeled, say a trolley, in Autodesk Inventor 2011, as a part file.
Now, I have to get the side and top views and give it to the fabrication department, which has to be in a 2D format.
My problem is in getting these views.
From the model, I tried to go for top and side views, but when viewed so, it does not show all the details clearly (for example, if there is a hole in the inner part, it does not indicate it by dotted lines, ....), and moreever it is not in a line diagram format.
So, can you help me out on getting these drawings?
I hope that my problem is clear now.
Thank you.
If you have already created a drawing... is it the view orientation that you cannot get? If so try the "Change View Orientation" button in the Drawing View dialog box. it allows you to set a cutom view for your base drawing view, you can then project form there. See Screenshot "View".
If your orientations are ok, but you cannot see the hidden lines of holes, as you mentioned, select from that same dialog box the "Hidden Line" button under "Style". Placing your base view with hidden lines will cause all projected views to show them as well.
Go to Inventor help and use the Search tab, search for Drawing Views. A font of knowledge in there for what you want to do. Good Luck.
Chris Benner
@Anonymous wrote:Hi.
Thank you.
Sure, attach the files here.
Still appears you need some training. Create an Inventor DWG file, and place your orthographic views. Its as easy as that.
If the Trolley in real live is made up of a number of pieces, it should be modeled this way in Inventor. It should be modeled of a number of IPT part files which are assembled in IAM assembly file.
A number of users use the single drawing to single part approach to using Inventor (useful in large models/assemblies). Smaller assemblies can be detailed within a single IDW with views associated with the final assemble and views of the individual parts for part-level details.
Sounds like you created a Trolley within a single part environment and are now having problems trying to make a number of your details visible.
No, I directly modeled in Autodesk Inventor in ipt format.
Once the software is open, I pressed ctrl+N and selected standard (mm).ipt file and modeled in it.
So, if I do in this way, won;t it be possible to get the drawing views?
To the extent I tried, I did not know how to get the screen that you have got. Was that screen avaliable for a ipt file?
I am still not getting it.
I will attach the file and please upload the same after getting the drawing views, sir.
I am not able to attach more than 3 files. Even if you say for 1 file, it will be sufficient sir.
Thank you very much.
The attached picture shows a assembly. It is make up of a number of parts IPT and sub-assemblies IAM to create the large assembly IAM.
One of the main trailer frame rails is a IAM. It is made up of 3 IPT files. I can create a detailed drawing IDW of each of the separate IPT files as well as a drawing of the frame.
Each crossmember is a IAM file that consists of 3 IPT files, the 2 end plates IPT and the main tube IPT.
This allows me to have detailed drawings for separate parts and sub-assembles rather than trying to create everything in a single IPT file.
If you posted a screen capture of your model we would probably have a better understanding of your problem.
Thanks for the parts, as figured you are trying to model everything in the IPT environment. Your HANDLE BASE should be a assembly made of of 2 IPT files. The first would be the angle-iron by it's self (should be using the Content Center) for it and a second IPT file of the solid shaft.
The MAIN BASE should be a IAM file as well with separate IPT files for each of the perimeter angle-irons (if each of the side-opposites are different) and a IPT file for the plate cover and an additional IPT file for the rib.
Read up on Assemblies.
You can always create a sub assemble for each of the handles and then when you place them in your main assemble they will be treated as a single item (you can still edit each part/IPT).
It appears that you are using the student license of Inventor 2011. Is that correct?
Are you taking a class to learn how to use the software? Has your instructor covered how to constrain sketches and how to create 2D drawings from the 3D model?
I notice that your sketches are not constrained (not even any dimensions)?
How did you create exact sizes without dimensioning?
You might start by reading this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
Ask your instructor to show you the Sweep command.
You could have done these 7 features (see attached) with one Sweep feature.
Extrusion 10,11, 12 should be done with one extrusion.
The entire part could be more efficiently modeled with only 3 or 4 features.
To attach an entire assembly here place all of the part files and the assembly file in one folder (you should already have this).
In Windows Explorer right click on the folder and select Send to Compressed (zipped) Folder.
Then attach the resulting *.zip file here rather than individual files.
