Good morning friends
Can you please give me your help and some of your knowledgement here!
The attached pic. from In2012, I manged some how to put a .bmp picture in the color style.
But as you see, it's not good, no good focus neither the piccture continue from the start to the ene, you see lines cutting the picture.
And when I use a color style that already exist in inventor, it looks so good.
The picture that I used is attached ( named 1)
I will use a better pic. I couldn't attached it here
Please, can you help me to put the better picture in Inventor 2013, and save it there as favorit, so I can use it over and over again ?
I want my drawings looks almost like my actuale product.
One more thig for my curiosity, see the attached picture please, This picture is from a magasine, do you see how good it is!, I want something near that for my drawing. can we! ( attached named 3)
My special regards to Ale & Daren
Sohaib
What you need to use is a "seamless texture" - Google for help, if it's something new to you.
Using a photo will 99% of the time never work without needing to use an image-editor like Photoshop or Gimp.
At the moment the left and top pixels are different from the right and bottom pixels, so you get a hard edge, which is visible as a repeating patch, instead of a smooth, constant texture.
here's an example of how to turn an image into a seamless texture - it's not the easiest of things though...
http://cokane.com/textures_tutorial.html
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
