Inventor General
AndrewBeekman9108
Message 1 of 6 (587 Views)
Accepted Solution
How to generate a guide rail to control twist
587 Views, 5 Replies
09-18-2012 12:00 PM
I am trying to model a forged steel table base so I can create some tooling to reproduce it.  See the attached photo of the base.  I am able to sweep along my 3D projected sketch path but there is a twist at the center that I believe I need a guide rail to control.  I have tried to draw a rail but it fails.  I suspect I am not drawing my guide rail correctly as to create the slight twist.  Any suggestions? I was considering drawing a shallow helix along the 3d sweep path but not sure that this is the beswt direction to head next.  I have attached the .ipt with the sweep (without guide path being used).
Thanks!
AB
*Expert Elite*
Message 2 of 6 (578 Views)
Re: How to generate a guide rail to control twist
09-18-2012 12:42 PM in reply to: AndrewBeekman9108
I noticed your first sketch was not constrained or making use of symmetry about the origin.
You might want to start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Then here and here for information on 3D sketches
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
AndrewBeekman9108
Message 3 of 6 (564 Views)
09-18-2012 06:21 PM in reply to: AndrewBeekman9108
I read through the tips, they were really helpful, thank you.   I still am confused about the guide paths though.  Since my profile is rectangular the bank/ twist is critical and I need to generate a guide path. Any reccomendations here?
AB
Employee
GlennChun
Message 4 of 6 (544 Views)
09-19-2012 12:05 AM in reply to: AndrewBeekman9108
Hi Andrew,
See attached IPT.  It's far from perfect, but it should give you some idea of how to control twist using a guide rail.
Hope that helps,
Glenn
ASM Development
AndrewBeekman9108
Message 5 of 6 (519 Views)
09-19-2012 09:16 AM in reply to: GlennChun
Hi Glenn, Thank you- that was very helpful. How did you create the path and guide rail? It looks like you used your construction lines on the 30, 40 &50cm planes to lay out a free-hand spline. I was trying to create these paths using an intersection curve and had no such luck getting them to be "tangent continuous". Thanks, Andy
Employee
GlennChun
Message 6 of 6 (513 Views)
09-19-2012 09:58 AM in reply to: AndrewBeekman9108
Hi Andrew,
I'm glad to hear that it was helpful. In addition to the 30, 40, and 50cm planes, there's an important plane at 60 cm above the floor ("table bot plane" in the browser). Here's what I did:
1. Roughly create free-hand 3D splines for path and guide rail. Each spline starts at a profile point.
2. Create 2D sketch points on the four work planes (Create a set of points on the +X side and then mirror them to the -X side).
3. Include the 2D sketch points in the 3D sketches for path and guide rail (Use "Include Geometry" command).
4. Add coincident constraints between the included points and spline points.
5. Right-click on the start and end points of each spline and select "Activate Handle".
a. Add a parallel constraint between each handle and Z-Axis.
b. Add a dimension to the handle.
6. Right-click on the midpoint of each spline (Each midpoint is located at 60 cm above the floor) and select "Activate Handle".
a. Add a parallel constraint between each handle and X-Axis (I forgot to do that in the attached IPT).
There are many different (and better) ways to model the two rails. My method above is just one example.
Glenn
ASM Development
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
