Inventor General
Valued Contributor
WillieArolf
Message 1 of 11 (832 Views)
How to flatten an elbow like a sheet metal development
832 Views, 10 Replies
10-30-2012 01:49 AM
I have an elbow with a slit on the other side and would like to use Flatten feature in sheet metal. How do I do it? I tried but an error pops-up, and I do not have an idea does it mean.
I have attach the file.
Maybe, anybody has a workaround if Inventor can not make it. Appreciate your assistance.
Thanks & Regards,
Willie
Autodesk Product Design Suite Premium 2012
Windows 7, 64-bit
Valued Mentor
mpatchus
Message 2 of 11 (822 Views)
Re: How to flatten an elbow like a sheet metal development
10-30-2012 04:05 AM in reply to: WillieArolf
See attached part.
Creating the sheet metal part using the available tools will usually result in a decent flat pattern.
Sometimes it hit or miss, at least in my experience.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Message 3 of 11 (807 Views)
10-30-2012 05:34 AM in reply to: WillieArolf
How will the part be manufactured?
Can you post a picture of an actual finished part?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Mentor
Valued Mentor
wh
Message 4 of 11 (774 Views)
Betreff: How to flatten an elbow like a sheet metal development
10-30-2012 11:53 AM in reply to: WillieArolf
This is a pretty good example, that people shouldn't trust very much in Inventor's Flat patterns, that are made from contour roll.
Walter
Valued Contributor
WillieArolf
Message 5 of 11 (753 Views)
10-30-2012 05:09 PM in reply to: mpatchus
Hi Mike,
Thank you for the assistance.
Is that the correct shape "Rectangle" after invoking the Flatten feature?
I thought there should be a slope kinda shape.
Thanks & Regards,
Willie
Windows 7, 64-bit
Valued Contributor
WillieArolf
Message 6 of 11 (751 Views)
10-30-2012 05:16 PM in reply to: JDMather
Hi JD,
The part is made of a flexible jacket (I think you have already encountered this issue before)... I am just looking for an alternative way in making use of Inventors ability in creating flat patterned using the sheet metal development.
Honestly, I am trying my best to convience my boss that we should stick in Inventor rather than shifting to solidworks. For the reasons that I am ever since a user of Autodesk products and pretty much used to its features and commands.
But, when it comes to flatting an elbow like shape, I do not know how to defend it.
That is why, I am trying my best to look for any alternative solutions by of course using Inventors ability.
Thanks & Regards,
Willie
Windows 7, 64-bit
Message 7 of 11 (717 Views)
10-31-2012 04:48 AM in reply to: WillieArolf
WillieArolf wrote:
Honestly, I am trying my best to convience my boss tha....
Have your boss invite a VAR to demonstrate this same part in SolidWorks.   :smileylol:
Message 8 of 11 (697 Views)
10-31-2012 10:27 AM in reply to: WillieArolf
Buy this program - cheap and they did have it free for 2011.  Not a salesman - just a user.  Download a trial and take a look.
http://www.ductpro.net/
Valued Contributor
WillieArolf
Message 9 of 11 (681 Views)
10-31-2012 05:06 PM in reply to: JDMather
Hi JD,
One of my collegue who is so eager to acquire solidworks (well, for the reason that he does not know how to use Autodesk Inventor) did brought my boss to one of the talks in solidworks and they have indeed should him that solidworks can do the sheet metal development after they flatten an object.
But, I did told my boss that they may have used a plug-in or third party software to the job. That is why I am asking for an alternative solutions like a plug-in for Inventor to the job.
Thanks & Regards,
Willie
Windows 7, 64-bit
Valued Contributor
WillieArolf
Message 10 of 11 (680 Views)
10-31-2012 05:12 PM in reply to: RobJV
Hi RobJV,
Thank you for sharing this, I will try to DL the trial and look onto it.
Thanks & Regards,
Willie
Windows 7, 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
