Hi all,
I'm very new to Inventor, but I'm hoping someone can point me in the right direction.
I have a bracket that I'm drawing, and it's made up of several pieces of 2mm thick steel.
When I extrude each piece, they join together, which I don't want. I want to keep each layer of 2mm steel independant from the others. If I could "untick" the 'join' button in Extrude I'd be ok, but I can't.
Can anyone tell me how to do this?
I'm using Inventor 2013.
Thanks in advance,
Chris
Attach your file here if you can't figure it out.
The CADWhisperer YouTube Channel
Ah! It's ok, I didn't have the model converted to a standard part, so that solved the greyed out issue.
I'll give your suggestion a go.
Cheers,
Chris
