Inventor General
New Member
a.sarmukaddam
Message 1 of 16 (2,212 Views)
How to export 3D points to excel?
2212 Views, 15 Replies
02-20-2011 06:35 PM
Please help.
Thanks in advance.
Employee
Hochenauer
Message 2 of 16 (2,175 Views)
Re: How to export 3D points to excel?
02-21-2011 09:31 AM in reply to: a.sarmukaddam
Open the VBA Editor from Inventor/Tools.
Inside the Vba editor, select Tools-> References from the menu.
Check the Microsoft Excel Object Library
Sub ExportWorkpoints()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oWorkpoints As WorkPoints
    Dim oWP As WorkPoint
    Dim oP As Point
    'get all workpoints in this part
    Set oWorkpoints = oDef.WorkPoints
    'create a new excel workbook
    Dim oBook As Excel.Workbook
    Set oBook = Excel.Workbooks.Add()
    Dim oSheet As Excel.WorkSheet
    Set oSheet = oBook.ActiveSheet
    Dim nRow As Integer
    nRow = 1
    'write the coordinates into separate columns, one workpoint each row
    For Each oWP In oWorkpoints
        Set oP = oWP.Point
        oSheet.Cells(nRow, 1) = oP.X
        oSheet.Cells(nRow, 2) = oP.Y
        oSheet.Cells(nRow, 3) = oP.Z
        nRow = nRow + 1
    Next
    oBook.SaveAs ("c:\test.xls")
End Sub
Hope this helps,
Gerald
Gerald Hochenauer(gerald.hochenauer@autodesk.com)
Inventor Principal Software Engineer
Manufacturing Group
Autodesk, Inc.
Gerald Hochenauer
Inventor Software Development
Autodesk, Inc.
Active Member
dansharpy
Message 3 of 16 (2,094 Views)
03-15-2011 03:18 AM in reply to: a.sarmukaddam
Id like to know more about this if possible? Could you give more detailed instructions please? Ive opened the VBA editor, checked excel object library but when i enter the text in a new module and try to run it, it comes up with an error.
Thanks, Dan
Active Member
dansharpy
Message 4 of 16 (2,054 Views)
03-17-2011 08:50 AM in reply to: dansharpy
Could anyone please give me some help with this as i'm completely stuck.
Thanks in advance.
Employee
Hochenauer
Message 5 of 16 (2,052 Views)
03-17-2011 08:54 AM in reply to: a.sarmukaddam
Dan,
I need some info on the error you are seeing in order to be able to help. What line of the code? What's the error message?
Gerald
Gerald Hochenauer
Autodesk, Inc.
Active Member
dansharpy
Message 6 of 16 (2,049 Views)
03-17-2011 08:59 AM in reply to: Hochenauer
Gerald,
It says "Compile error: User-defined type not defined"
If i click "ok" it then highlights the line of code "oBook As Excel.Workbook"
Does that help?
Im creating the module under "Document Project"
Thanks.
Active Member
dansharpy
Message 7 of 16 (2,047 Views)
03-17-2011 09:07 AM in reply to: dansharpy
Sorry, that was the wrong one actually! Id forgotten to check excel object library.
With that checked it now reads "run-time error '13': Type mismatch" If i click debug, it highlights the line "Set oDoc = ThisApplication.ActiveDocument"
Any ideas?
Thanks, Dan
Employee
Hochenauer
Message 8 of 16 (2,043 Views)
03-17-2011 09:09 AM in reply to: dansharpy
Are you running this from within a part document?
Gerald Hochenauer
Autodesk, Inc.
Active Member
dansharpy
Message 9 of 16 (2,040 Views)
03-17-2011 09:13 AM in reply to: Hochenauer
It's an assembly, but only with <20 parts. Will it only work on a part document then?
Employee
Hochenauer
Message 10 of 16 (2,019 Views)
03-17-2011 09:44 AM in reply to: a.sarmukaddam
The example I wrote is for a single part document - it is a generic example that takes workpoints within this part and exports their locations.
as opposed to
 Dim oDoc As AssemblyDocument
In order to extend the sample to assemblies, you'd have to iterate over the assembly component Definition structure(Assemblies can contain sub assemblies,....) .
You'd need to know about Component Occurrences and transformations in order to get all the points to show up at the assembled locations.
Unfortunately I can't spare the time to write it - I need to wrap up things before leaving on a 3 week business trip. Maybe somebody else can pick it up or you get some training. It is quite a good example to learn how programming Inventor with VBA works.
Gerald Hochenauer
Gerald Hochenauer
Autodesk, Inc.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
