i am wondering how or were the contraints list is located or how to edit them or get rid of them
Solved by JDMather. Go to Solution.
See the attached image.
At the top of your browser there is a drop down next to Assembly View that says Modeling View.
If you go to Modeling View you will see a folder with all of your constraints.
You can right click to delete or edit.
Are you really sure you want to do this?
Post screen shot of left side of your screen - it hasn't changed as far back as I can remember.
(you are in an assembly - correct?)
Beauand can you post a full screen shot of your computer so we can highlight it for you. Its there
Do you know what the model browser is in the assembly (iam file)?
And why did you state "assembly drawing"... In the cad world we typically refer to the "assembly model" (iam file) as the 3d file where you actually put your model together/constrain/place parts ,etc.... Then the assembly drawing (idw or dwg file) is the 2d sheet where you place front/rear/side,etc.. views of your assembly model.
Make sure you are in the iam file and look at the top of the model browser (that tree like view of all your parts in the assembly)
yeah i am in an iam. file type. I havent use inventor in a really long time so i am kind of learning it all over again. I just cant remember how to get that window you showed me on the side.
@Beauand wrote:I just cant remember how to get that window you showed me on the side.
I'm guessing that at some point you turned off your Browser "panel bar".
If you attached screen shot (as requested twice) you could remove all doubt.
Go to View>User Interface and click on the drop down arrow and select Browser.
thanks you helped out and im sorry i am at work and its been super busy i know it would only take a couple mins but thanks for the hlep
