Inventor Forum
How to edit bill of materials.
2 REPLIES 2
rsagan85
1258 Views, 2 Replies
I have created a part that is going to be a bar.  However when I create the drawing for unit QTY I am getting an answer in inches, this is not what I want.  I want to know the quanity that I have for example 2 each.  How do I go about changing this from inches to each?  I have done several searching and still coming up empty for now I have just edited it in the bom on the drawing and put what I want in.  However I am thinking there is a better way to do this. I have also attached a screen shot to hopefully better explain what I am trying to do.
2 REPLIES 2
blair
in reply to: rsagan85
Go into the BOM for the Assembly, select the Choose Comuns (yellow & white icon with red down arrow), then drag the (Item QTY) to the BOM header.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
mpatchus
Open the part and check to make sure the Base Quantity for the part is set to EACH.
Parts that are created from content center (structural steel, pipe, etc.) typically come in as inches for the base quantity.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
