Inventor General
haisin.rusli
Message 1 of 14 (4,322 Views)
How to draw segment elbow 90 degrees and create Flat Pattern ?
4322 Views, 13 Replies
01-16-2013 08:21 PM
I would like to know how to draw segment elbow 90 degrees ( segments are not equal ) and create Flat Pattern for each of the segments - using sheetmetal in Autodesk Inventor?
Best Regards,
Haisin Rusli
*Pro
sbixler
Message 2 of 14 (4,287 Views)
Re: How to draw segment elbow 90 degrees and create Flat Pattern ?
01-17-2013 03:56 AM in reply to: haisin.rusli
Please always include the Inventor version you're working in.  If I produce a 2013 solution, will you be able to open it?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
JDMather
Message 3 of 14 (4,278 Views)
01-17-2013 04:43 AM in reply to: haisin.rusli
Can you attach the ipt file of what you attempted.
Search here on sheet metal gore(s) might turn up the solution.
Trimmed surfaces and Thicken.
I would create the surface model and then Derive Component into each gore part to Thicken and Flat Pattern.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
haisin.rusli
Message 4 of 14 (4,239 Views)
01-20-2013 06:36 PM in reply to: haisin.rusli
Hi Sam B, I am using Inventor Professional 2013 - 64 Bit.
Hi JDMather, here I attach ipt file that I attempt to draw.
Best Regards,
Haisin Rusli
Distinguished Contributor
TheCADWhisperer
Message 5 of 14 (4,189 Views)
01-22-2013 07:12 AM in reply to: haisin.rusli
Check this example.
haisin.rusli
Message 6 of 14 (4,163 Views)
01-22-2013 10:45 PM in reply to: TheCADWhisperer
Hi TheCADWhisperer,
it works good! How did you make it?
Please explain the steps.
How to split each segment ?
Best Regards,
Haisin Rusli
*Pro
sbixler
Message 7 of 14 (4,136 Views)
01-23-2013 05:10 AM in reply to: haisin.rusli
You can find this out for yourself by examining the files.  Open Gore2.ipt, for example, and notice that it is a sheet metal part with only one feature: a derive of Elbow Master.ipt.  Right click on this feature and choose Open Base Component.  This will open the file Elbow Master.ipt.  Now pull the End of Part marker from the bottom of the browser to the top (everything disappears).  Now pull it down one step at a time and examine what TheCADWhisperer did at each step.  If there's anything you don't understand, just ask here.  But you'll learn a lot more by trying to figure it out for yourself.
Sam B
RobJV
Message 8 of 14 (4,109 Views)
01-23-2013 02:21 PM in reply to: TheCADWhisperer
That is a good way of doing it and I am sure it would be within manufacturing tolerances but a big issue in modelling this type of ducting is the interference problems between adjoining sections of the "lobster". (Simply zoom in and you will see that all the sections interfere.)  To avoid this, the op could specifiy a small angle between parts in the skeletal sketch (on the interior side) or use a program like duct pro for inventor.  It is cheap and will pay for itself in no time even if you only do ducting like this once in a while as I do.  (I am not associated with duct pro in any way.)
Rob
haisin.rusli
Message 9 of 14 (4,035 Views)
01-31-2013 11:44 PM in reply to: haisin.rusli
@TheCADWhisperer / Sam B,
After Sweep Surface, how to trim surfaces because I have no workplane ?
Please advice.
@RobJV thanks for the information.
Best Regards,
Haisin Rusli
*Pro
sbixler
Message 10 of 14 (4,026 Views)
02-01-2013 05:01 AM in reply to: haisin.rusli
What do you want to trim?  You've got the surfaces you need, now thicken them individually into separate solids.
Sam B
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
