Inventor Forum
How to divide sketch ?
22 REPLIES 22
Message 1 of 23
Kwin
9320 Views, 22 Replies
Has Inventor a "divide" command, similar to ACAD ?
22 REPLIES 22
Message 2 of 23
in reply to: Kwin
wrote in message news:4979530@discussion.autodesk.com...
(had to go look in acad to see what the Divide command did...it's been a
while) Here's one way to get that functionality in an Inventor sketch....
Lets say you need a 26" line, divided into 6 equal segments:
-Create a construction line, and dimension it to the 26" overall length you
need. Check in the parameters dialog and make a note of the parameter
that's assigned to that dimension. In the screencap, mine is d1.
-Now place a sketch point at the beginning of the line.
-Invoke the Rectangular Pattern command. Choose the sketch point for the
geometry, and the construction line for the direction. Make sure the
preview has the array going in the right direction.
-Enter the number of points you want, which would be seven (the number of
segments you want to divide the line into plus one).
-For the spacing, enter in d1/6
[see divide1.jpg]
This will get you a series of points that effectively divide the line into
segments. There are other ways to do this as well, but this is one of the
quickest and most versatile for times when you need a lot of little
segments.. Everything stays intelligent, and can easily be manipulated as
needed. This method has lots of useful variations. I used it this week to
place evenly spaced rivet holes in a sheet metal piece. The holes had to be
3/4" spacing, with as many as could fit on the length of the part in a
centered pattern. I had several pieces of varying lengths to model. Here's
what I did:
-Sketch a construction line representing the entire array as above.
Constrain it's centerpoint to the middle of the part so that the line always
stays centered.
-Dimension the line, and for a dimension value, enter .75 * X. Play with
the value of X until the optimal fit is achieved. The value you settle on
for X will be the number of segments the line is divided into, so the number
of points for your array will be X + 1.
[see divide2.jpg]
Cheers,
Walt
Message 3 of 23
Kwin
in reply to: Kwin
THANKS A LOT 😄
really help !
Message 4 of 23
in reply to: Kwin
Here is another method.
Dimension the line you want to divide.
Place a point at the end of the line.
Do a rectangular pattern of the point and to enter the length of the line simply click on the dimension.
Expand the rectangular pattern dialog box and select fitted.
If you later change the dimension the divisions will update.
There are other methods as well. I prefer to NOT pattern sketch entities in most instances and rather pattern features. The Rectangular Pattern-feature tool is misnamed as you can pattern along feature shapes.
Message 5 of 23
Kwin
in reply to: Kwin
Thanks again.
I like this way.
Message 6 of 23
zaharmilan
in reply to: Kwin
How to divide a arc in 5 parts in sketch in Inventor as in AutoCAD?
Please help me.
Message 7 of 23
JDMather
in reply to: zaharmilan
Please help me.
Attach your file here.
Message 8 of 23
zaharmilan
in reply to: JDMather
Could the two arches divided into five equal parts?
Message 9 of 23
JDMather
Given that this is your first post here - I feel compelled to ask why you are sketching in a drawing?
Can you expand a bit on your problem statement and design intent?
I suspect there are better ways of doing whatever it is you are trying to do.
Message 10 of 23
zaharmilan
It doesn't matter where the drawings (Create New File -> Metric -> ISO.idw -> Sketch) or (Create New File -> Metric -> Standard.ipt -> Sketch) but how to divide arcs (no matter the number of arcs, as it should do as in AutoCAD option "Divide" and to be as polylines) into five equal parts?
Message 11 of 23
JDMather
I could show you how, but I don't understand why you would want to do this.
Can you supply more information on your design intent - ignoring AutoCAD techniques - I think there might be a better technique in Inventor.
Edit:  And yes, it does matter where (drawing or part sketch).
Message 12 of 23
zaharmilan
Hello JDMather,
Here's an example.
Thank you in advance on response.
Message 13 of 23
zaharmilan
I temporarily solved the problem with arc line between two point (arc length).
Whether there is a better solution?
Message 14 of 23
JDMather
I have no clue what your design intent is all about.
Provide more information and/or finish the design as best you can and then post that file(s) and I will show how I would have done the design.
Message 15 of 23
zaharmilan
How to share (divide) the two arc on 5 equal parts?
Message 16 of 23
JDMather
I assume you mean something like attached file.
Message 17 of 23
zaharmilan
I am sorry, I didn't attach file.
Message 18 of 23
JDMather
Here is your file with 5 equidistant divisions.
Message 19 of 23
zaharmilan
Message 20 of 23
in reply to: Kwin
Here i have a sketch that contains of 50 dimensions. But now i want to split the sketch as sketch 1 & sketch 2 of each has 25 dimensions equal. Is it possible in auto desk inventor???????? Please help.
