Inventor Forum
How to delete unused parameters?
4 REPLIES 4
sohmoh
8120 Views, 4 Replies
I have assymbly wich linked to excel sheet.
I can delete the excel sheet from the assmbly and its parts too, but I can't delete the unused parameters in "List parameters "
And, I can't link a new excel sheet to this assembly, even if I changed the name or made a new one,why?
I use inventor 2012
Thank you
Tags (2)
4 REPLIES 4
karthur1
in reply to: sohmoh
"Can't add new excel sheet....", why not?  Does it give an error or what?
For the parameters, as long as the parameters are not used,  you should be able to right click on it in the list and choose "Delete parameter".  Dont select it first, just right click on it.
sohmoh
in reply to: sohmoh
I got an error msg, that they both of them have the same source or bath.
ButI did wat you learned me, it went perfect, and furthermore, I deleted the used parameters in the assembly and I could delete the whole parameters and link a new one.
Thank you for your time to read my quastion and answer me, you saved my day.
last question please, when I linked the new excel sheet and want to use it in sketch for exemple, and when I want to replace the dimention, I click on "List parameters" and that's just fine, but why I still have the old one's in he list?
Again, many thankx
regards
Sohaib
karthur1
in reply to: sohmoh
Again, many thankx
regards
Sohaib
Dont quite follow you there.  To delete the folder, open the parameters dialog, right click on the xls file name and choose "Delete folder".  If some of the parameters that are in this linked file are used in the parameters, that parameter will not be deleted, but it will be moved to the "User Parameters".  The only way to totally get rid of it is to either remove it from the model parameter.
Tip:  to see where a parameter is used, just hoover the pointer above the parmeter name in the dialog. It will show something like "parameter dim1 is consumed by d12".  If it does not show anything, then it is not used and you can right click and delete the parameter.
If that doesnt help, make a screen shot of what you are seeing and post it here.
sohmoh
in reply to: karthur1
Hi again,
See my screen shot
As you see, in the "parameters window" there is some parameters, let' say one or two, from the previous excel sheet, the one you help me to delete it, so I wondered if I could delete these parameters since I don't use it anymore.
Many thanks to your efforts
Sohaib
Tags (2)
